How to build a low beat Diver, or how to make a almost perfect rep a bit more perfect
jaycey
74
I use the main plate from the chines movement for my mod. So no problem to fix the dial and the movement to the case.
Sent from my iPad Air 2
Sorry. I missed the great big main plate in your picture identifying the parts you used from the Asian movement :bang:
Nice work, I think I will do one of these ;)
watch_man
174
Hi Chris,
thank you very much for sharing this brilliant turorial - I immeadiately saved this thread to my favorites.
I also used to be a Swatch collector in my younger years (more than 20 years ago :cry2:) but I sold all my (S)watches except for one or two automatics. So I think I will also try to do the mod and thank to you with much less fear to do something wrong :)
chris3007
9,407
120
Just to make it clear, because I get many PM's like "thanks, I want to try that too"
But it's not a easy mod!! You must be familiar with the work at watch movements and you need good watchmaker skills for something like that.
It's just a warning.
Sent from my iPhone 6
oysterling
70
I just want share that pic from the mod. My FC diver next to the SS diver. Two true beauties
Mate, I don't know if that is intended but the bezel on your fc is misaligned with the brushing running from 8 - 2. Is that correct?
Slowlex
DO NOT TRADE WITH ME
24/7/13
3,153
61
Great thread! What do you use for timing with you iphone?
Chris
chris3007
9,407
120
Nice catch. I never notice that because the brushing lines at the noob FC Diver V3 are nearly invisible. You can see them just under strong light. But thanks for the hint. I will fix it.
oysterling
70
At your service. [emoji4][emoji106]
Bozz
2,748
Amazing and useful work chris! My compliments. Clean and cheap mod, your swissnese rocks!
Many thanks for share.
paulvillo
696
51
How to build a low beat Diver, or how to make a almost perfect rep a bit more...
Thanks a million Chris! PM replied ;)
hub6152
1,606
Having been to an AD this afternoon and seen the "tick" of the low beat rate AP 3120 movt this is a must do mod as it's probably the most obvious "tell". Thanks for such a comprehensive post on how to.
wariactive
201
Is this okay? Sorry no idea on this but i would like to buy this piece and swap the movement to my Diver. Hehe
Sent from my ASUS_T00J using Tapatalk
chris3007
9,407
120
The movement is ok but I would not do it if I had no idea about a movement [emoji6]
D
d4m.test
Guest
This is an amazing AP Diver heart transplant pictorial:) Rep points given, very well deserved.
Who needs a Tissot Powermatic when You can do this:) And I have a 2840 and a 2846 around, fresh to some day go into vintage Rolexes - have to think about this and review this thread carefully several times. I could do the movement swap and transfer the rotor - but it´s already enough of skills 4me and they end right there. DWO and bridges..(?)..
Wow, I admire Your skills and taking the time to make some nice and easy to follow pictures was a great idea. Thanks a lot:)
