Can't get away from the Planet Ocean's - been living in the 42mm world since day 1, have now graduated to the 45.5 world, and want to franken up a PO Lite that I purchased here. Any guidance would be appreciated!
The starting point...
A 45.5 Planet Ocean "Lite" that is supposed to have same case as the UPO. Watch came with what I assume is a DG4813 movement, near-gen sized hands, and a stripped crown / tube.
What I'm thinking...
Purchase Gen crown / tube from Ofrei.
Purchase Gen dial from Ofrei.
Install them.
How hard is it to install a Gen tube?
By leaving the DG4813 movement, I would not have to replace the hands (from what I hear, Gen handset needs an ETA movement, and won't work with the DG4813), and everything should line up.
So, how nuts am I?
Is the dial really that different from Gen on this model? Sometimes I think the dial markers are too small, other times they look very close in size. Color on the dial markers is also an issue (or is it)?
What are your thoughts? Is this doable?
I can get the Gen parts from Ofrei for about $280.00, so I'd have a 45.5 PO with gen dial/crown/tube, gen-like hands/case/bracelet for about $400.00 out the door.
I did / have consider the UPO, and save myself some time and $$$, but from what I can see, the dial markers / color on the UPO look different than the Gen dial markers. Is that true, or is it just me?
Again, any guidance would be appreciated!
Jim (kohanjj)
![pol0.jpg](http://www.jameskohan.com/watches/1226/pol0.jpg)
![pol1.jpg](http://www.jameskohan.com/watches/1226/pol1.jpg)
![pol2.jpg](http://www.jameskohan.com/watches/1226/pol2.jpg)
Install them.
So, how nuts am I?
Jim (kohanjj)
