Help with 12 dial markers
GHatch
Horology Curious
19/9/21
Hi All,
New member and first QC.
Can anyone advise if the markers at 12 are positioned correctly one seems more pronounced than the other
Rx4Time
Supporter, Panerai lover
11,099
8,171
I don't understand your question? All of the indices are present and facing towards the center so unless there's something I'm not seeing, your question seems pointless... You are aware that the lighting is not even and therefore will not have the same level of reflection depending on what part of the watch face you're looking at.
Plaasbaas
IWC-hoarder and PAM-hunter
2,686
6,128
If you want to make sure that the markers at 12 o'clock are arranged exactly parallel to each other,
this is hard to make out on the photo, due to the lighting.
Rx4Time
11,099
8,171
There everything looks perfectly fine...
GHatch
Horology Curious
19/9/21
Hi guys sorry if I wasn’t clear I mean the 2 markers directly above the B
One looks raised up higher the other (the left one)
But as you have said it’s possibly the lighting
here is another pic from a different angle
