So I began this project last year. The watch started as a VSF rep from a TD and so far, I've swapped out and added a Gen Dial, Gen Bezel assembly including ceramic insert, Gen crystal, Gen hand set, and Gen ETA 2836 movement. I LOVE how it has turned out thus far. However, the biggest tell on my wrist (although very subtle) is the bracelet SELs. They are not recessed like the Gen. They are almost flush across the lugs. As you all know, the Gen SELs are recessed a bit from the lugs. Someone a while back had mentioned using an ARF bracelet, but I don't know if that would correct this issue. Is there anything that can be done short of drilling new spring bar holes in the lugs to lower the SELs? I would greatly appreciate the help from anyone who knows how to correct this.
