Help needed - Changing Straps on a Panerai Carbotech PAM 1118
luminarae
23/2/24
Hi RWI community.
Have been lurking a while and finally decided to dive in and get my first rep, which is the one in the title. Wanted to change the straps on this watch to a better fitting one (small wrists), but I can't for my life figure out how to do it. It seems that most carbotech models should be using the spring bar system for Panerai watches (as far as I can tell), but no matter how much I push there seems to be no give in the spring. Would love it if anyone could provide any advice on this. Thanks in advance!
Unknownwatchmaker
681
231
Boston, MA
I can no speak specifically to the carbotechs (i have all the other materials ;) but from my experience it is always either a spring bar or more likely a screw. If it is not the former then it should be the latter. Best of luck! Swapping straps is the best way to change the feel of the watch, and an easy upgrade for any rep.
luminarae
23/2/24
Thanks for the insight! Figured it would be a springbar, but I can't get it to budge no matter how hard I push on the divot. Also see no obvious screwheads despite using strong flashlights to shine a light on the bar holes, so this thing has got me pretty stumped!
nikefit
115
46
If i'm not mistaken, the lug holes on the carbotech reps are fake (they will not go through no matter how much you push on it). You should remove the spring bar through the gaps on the strap itself. Please correct me if i'm wrong.
Reactions: Watch-addict
Unknownwatchmaker
681
231
Boston, MA
Yeah, the head of the screw pin should be very obvious on the side of the lugs. I am not sure what other type of locking mechanism the panerais use — they do not have the integrated spring bars like the new AP ROOs, etc.
might be helpful to post a picture
25,577
You need to press both sides of spring bar in not just one side
And have proper tools you can crack the carbon fiber case at the lugs if you apply enough leverage in the wrong area. These are not steel cases.
Plaasbaas
IWC-hoarder and PAM-hunter
3,294
7,963
Should be normal springbars.
Did you buy the watch new or second hand? Just asking, because if it was second hand somebody could have made the mistake of using springbars AND tubes. The latter are only intended for models with screw in mechanism. In that case there is not enough space between lug and tube to get to the shoulders of the spring bar with any removal tool and it is a pain in the neck to remove the straps. Almost impossible without destroying the strap and/or the tube.
Be very careful though as said above and don't use too much force. The carbon can crack or break easily and then your whole case is bricked.
muiramas
Aristocrat
18/1/17
6,105
8,133
This - the holes are fakenand don’t go through the lugs. If try and push them you’ll snap the lug off. You need to take the spring bars off as though it doesn’t have drilled lugs because it doesn’t.
B2Stealth
15/8/20
Can you share how we need to remove the spring bars then? I’m at a loss trying to swap straps on mine.
locvs
403
422
THe holes on the Reps are fake. You need to use a simple spring bar tool. Just as schown in the video.
B2Stealth
15/8/20
Thank you. I’m used to Gshock watches and have never owned a watch that requires a spring bar tool to replace the straps. Just ordered a spring bar tool. 👍
Podraza
74
15
Plymouth, Mn
Has anyone drilled out those fake drill lugs? I made the mistake to use an authentic strap with metal insert tube. Now I can’t remove the strap. Bummer
locvs
403
422
You cant, as the fake holes don't align with the real ones.
You can use dental floss to remove the strap. It works even with tubes.
Reactions: Podraza and Reaps
