Help me decide based on ease of servicing
idfrwi
9/9/16
29
I'm looking to buy a Tudor Pelagos Black. Options are ZF version with A2824 or V6F version with decorated miyota 9015. I'd be happy to be able to replace the movement when it's time to service it on my own.
On which of the two will it be easier? The decoration slightly frightens me.
trailboss99
Head Honcho - Cat Herder
Administrator
42,554
12,994
Since it's a closed caseback the decoration means little or nothing. Both movements are available on eBay and other places tho the 9015 will be just a plain MVT.
Personally I'd go the A2824
idfrwi
9/9/16
29
Thanks! Are there any dimension differences because of the decorations? Will a vanilla 9015 from ebay just fit into the case?
freediver
2,772
1,389
it should fit since decoration can only increase dimensions and not otherwise
Personally i would avoid decorated movements if i could
trailboss99
Administrator
42,554
12,994
If by decorated you are referring to engraving on the MVT it will make no difference at all.
idfrwi
9/9/16
29
I'm looking at the movement picture in here, it doesn't look like only an engraving compared to the original movement. I'm not an expert at all though, that's why I ask.
tripdog
Super Moderator
22,627
18,122
That's a standard 2824, maybe you're looking at the movement retaining ring, which isn't part of the movement anyway. A 2824 is a 2824, if it's what's in the watch then it can be replaced by any 2824 - Swiss or clone.
Or maybe you're looking at the rotor, this can be swapped over if you want to the replacement movement.
