Help in SEL mod
Lbsilio
155
72
The 12 clock SEL is at the same height of the case, I've think if is possible to sand the SEL to make it thinner and get more perfect at the case...
If is possible, which sandpaper I use to keep the brushed style???
Enviado de meu SM-N950U1 usando o Tapatalk
32,784
59,030
400 grit is a safe starting point. Keep a constant check on the curve, it's easy to get a straighter spot than you want. Go up or down in grit as needed to be more/less aggressive. Sand in same direction as brushing. Pay attention to uniform slope from center to outer edge. When done, touch up brushing with green Scotchbrite.
Oascom
Watchmaker / Modder
Vendor (Watch Repair)
4,373
4,955
WWW.WATCHMAKERUSA.COM
Yes it is possible, but it is also easy to mess it up. Just do it slowly and constantly check your progress
Lbsilio
155
72
Thanks! After I do the job I post how it become.
Lbsilio
155
72
"Pay attention to uniform slope from center to outer edge" i don't get this part, sorry... could you explain better?
32,784
59,030
32,784
59,030
Got it, and, i know that you said that is to use 400 grit but I have 360 grit, can I use the 360 or is better I buy a 400??
You should have an assortment, 360 should be OK to start but I wouldn't rely on just that. Get some other finer grits, 600, 800, 1000. See what works well for you.
Lbsilio
155
72
Ok
Lbsilio
155
72
Before I sand it, you guys that have more knowledge than me, which is better??? Up or down?
Lbsilio
155
72
After you guys oascom KJ2020 telling me how to do, this is the result... just one SEL, the 12 o'clock. After I do the other side I post here how it become.
I use the 220, 360 and 1200 and finished with Scotchbrite.
32,784
59,030
Left side looks perfect bro. Right side could use a little more off the top. That's what I told my barber, haha. Really nice work!
Reactions: Lbsilio
Lbsilio
155
72
I use as base this one I've seen on Instagram
Reactions: KJ2020
Lbsilio
155
72
Oh... thanks!, I notice that and fix it later... but thanks for tell
Reactions: KJ2020
Lbsilio
155
72
KJ2020 oascom i lost the Spring bar that came in the bracelet, so i buy this one but this isn't thigh and became loose, is possible to make it tight??? Because if I let this how it is the bracelet will be knead.
Sent from my SM-N950U1 using Tapatalk
Lbsilio
155
72
I tried with tape but does not good at all
bc1221
Put Some Respect On My Name
30/4/14
4,079
454
I don’t think it looked that bad from the start.
As for the spring bar... I don’t think they use a spring bar for that link. I thought they were in place with a pin and pushed together with the rest of the link. Idk. I’ve never taken that part apart before but from the pics I’ve seen, it wasn’t a spring bar that was holding that last link in place against the SEL.
bc1221
30/4/14
4,079
454
by the way, is that a 16800 build? I’d love to see some pics of it is.
It looks like it was a JF base. Which dial did you use?
*edit*. Nvm. I was looking at the pic you found on Instagram.
