Help a first-timer: worth upgrading A2892 to SW300?
Enthusiast101
139
33
Yeah the movement is straight plug and play. You may have to swap over the date wheel to get the correct font though. Bit sure if it uses the default font or not. You could swap over the rotor to get IWC branding on it as well but it doesn't really matter since it's a closed case back.
Thank you, this is good to know!
sorginator
87
76
This is only partly true. Yes you'll have to switch over the date wheel and rotor but the bigger problem is the pinion. There are a bunch of different lengths for them and if you get the wrong one you'll need to swap it over from the clone. So far nobody has reported exactly which model of the 2892 has the proper pinion length but I'm pretty sure I read somewhere that someone just swapped the pinion. I get the feeling however that if you are going to the length to get a proper Swiss movement into a rep that has a solid caseback, you want it to be fully Swiss, not a Swiss/Chinese hybrid. Unfortunately, I don't have the information about which one is a plug and play so if you want to want it to be an easy swap, you'll have to do some digging yourself.
Geonor
1,434
3,625
Norway
Right the pinion height as well can be an issue.
Reactions: sorginator
