GENLIKE Crown Pin Mod
kampachi
841
33
Okay... so while i was browsing through gen Panerai pictures, i kept noticing how different the pins on them crown guards were different with our reps. I already knew how gen pins were chambered on the top that gives it the recessed look. A common misconception is how the pin is recessed by a hair line which is what most modders practice for their crown guard mods. I wanted something more, something gen like and i knew Noob cg pins have a similar gen like appearance so i took out my Noob crown guard, removed the pin and tried to study it under the loupe. Well well, all this while Noob has already done the chamfering for us. However the common issue with Noob cg pins is that they are not flush with the crown guard, usually extruding out a little.
So all that's left is to push the pin back into the crown guard and we will have a gen like appearance on the cg. However, i tried pushing in with a chopstick and even used a rubber hammer but no luck. Apparently, the bottom tip of the cg pin is a little too fat as the factory did not shave them properly. So, out came my dremel tool and its diamond bit. CAREFULLY, i shaved the edge of the pin's bottom where the grooves are, slightly shortening it along the way. It took a few tries to prevent over shaving and i had to regularly push the pin back into the cg to check if its enough.
Here comes the 'barbaric part' of the mod. After a few attempts, the pin was finally flushed with the cg. However, another issue appeared. When i fixed back the lever and pushed back the pin, i came to notice that the pin was a little lose. A few rounds of pulling out the lever will make the pin extrude again. To fix that, i applied some super glue (yes) on the back part of the crown guard pin hole. Once dried, pin was all good i can't be any happier. No pin polish or shaving will get me this look that i want.
The result:
Sorry for the lack of real pictures as i was too focused on the mod. Hope the diagrams can help yall to get the gen like effect!
A gen cg pin for reference:
mysterio
9,794
864
Nice guide but the pictures are too small to be of any use.
kampachi
841
33
Might be one of the issues where browser or forum resizes the pics? Anyone else facing the problem? If happens frequently on sales thread for me... Wonder what's wrong.
winz
189
very useful thread, but i can't push out pin from CG
how to push out pin from cg? my noob CG pin too hard to push
my h-fact CG pin easy to push out, any solution to this? :(
kampachi
841
33
Use thor's hammer.
kilowattore
13,954
6,393
Very smart tip mate, thanks for sharing :)
Maybe one could use a manual file or sandpaper to shave the back of the pin instead of the dremel. It could be easier this way to control how much you shave the pin.
ALE7575
Section Mod
19,845
419
Thanks kampachi
This is a nice and helpful thread
You have perfectly defined this matter and the solutions
Makers should know about that
Rep points added
ALE
kilowattore
13,954
6,393
Added to my tutorials list, thanks kampachi :)
PAM1983
1,174
Im not fully following the mod. i understand the "Thors hammer approach" but will this push the crown guard pin down a bit or does it have to come out to shave down the bottom a bit for it to push back down token spec?
ALSO... besides the PIN mod what else needs to be done to crown guard to "look" gen?????? Or is this the only mod?
kampachi
841
33
Noob crown guards have a very gen like finishing unlike H-Facs. As for the pin, yes you need to remove the entire pin by pushing it out from the bottom of the cg. You can use your own method of shaving the bottom of the pin. I use a dremel diamond bit to do the work but be careful not to lose your pin.
lmmo
787
Do you need a dremel diamond bit to do it or a file will be enough?
How easy is for a noobie to mess everything and destroy the CG and pin? [emoji23]
[MENTION=77371]kampachi[/MENTION] do you do this type of mods to fellow members of the forum?
Thanks!
kampachi
841
33
Thanks!
Its a simple mod and a file is enough but you need something steady to hold the pin. Err, i dont think you want to send me your pin over a 10 min fix :)
Sent from my Super Rep iPhone using Grade AAA Tapatalk
