- Brushing of gear train without following plating
- Change of SN screw
- Swap of rep Incabloc for Gen (even lyre spring)(perfect)
- Polished wheels (this cannot be seen clearly in the pics
- Swap Crown for H maker one. (It should be "Slim", but it cannot be seen in the pics)
- Seemingly polished and flattened CP
- Likely relume
OFFICINE PANERAI inscription in Noob replicas, as explained cearly in my thread :
The Last Steps to the Gen(Part II)-Crown-Pin gasket-Gears-Wheels&Engravings
http://forum.replica-watch.info/vb/showthread.php/pcteam-last-steps-134437
is completely uneven, and there are many watches with incorrect engravings.
Yours is good enough and have just the problesm of a big distance R_AI but it is uniform, crisp and clean Anyway this is an issue of the watch and not a problem of the modder.
The Swan Neck spring has its rep shape and different to the gen one. But if you have not contracted this mod it is not a problem of the modder either.
Screws of the whells are clearly rep, mainly in Crown whell. But, again, if you have not contracted this mod it is not a problem of the modder either.
ALE
