Franken Rolex Datejust build with VS 3135
matzemedia
474
1,066
Some years ago, my Datejust 1603 was stolen. I got this watch from my father, who got it from his father. So it was a bit more than just a watch to me and I decided this year to get a similar Datejust. After searching here at the forum, I found that it is not that difficult to create a Rolex Datejust. @johloo helped me with some tips on how it could work.
My idea was to find a case where I can mount a 3135 movement. And it must be a case with plexi crystal. The most obvious is the case from rafflesdials. During my search of the parts, I found an auction on eBay for a gen case with gen dial. So I got unreasonable and bought it.
matzemedia
474
1,066
Here comes the story about putting everything together. The Rolex 16030 case was delivered with a 3035 movement. The fact that a lot of people remove the movement from the Datejust and use it as replacement in more popular watches, the Datejust parts are affordable. I decided to buy a VS 3135 movement because I had some good experience. It is reliable and most similar to the original 3135. But what I did not know, it is not identical in size to a 3035 movement. To fit it into the case, I have to reduce the diameter of the movement or increase the diameter of the case. Working on an original case is beyond my limits. So, I decided to work on the movement and dremel it. It was a painful process and the first time that I realized that the movement is built from bras.
  • Wow
Reactions: Tony-Soprano
matzemedia
474
1,066
OK, the rest of the build is straightforward and just putting everything together. The dial feeds are fitting exactly at the movement, so there was nothing to change. The old Datejust watches use a calendar typo with an open 6 and 9. The VS 3135 movement is shipped with another datedisc. I found a thread where people ask for buying a 3135 datedisc with open 6. You can get a gen datedisc but not for less than 300 EUR. I could only find one dealer who sells them as aftermarket parts. I bit the bullet and ordered the part for about 50 dollars. Well, it does its job.
Reactions: Dino2018
matzemedia
474
1,066
Actually, the rest should go by itself. But things sometimes go differently than planned. The case was delivered without a crown. I was still lucky enough to have a Datejust crown in my part's assortment. Unfortunately, the thread did not match. After a lot of research and measuring back and forth, I realized that Rolex had changed something in the model years and that the only way to make the case compatible with the modern crown (24-604) was to use a special tube.
Luquito
896
709
Absolutely fantastic build! Great job!
I’m sure it keeps the memory alive of the sentimental piece that was unfortunately stolen.
Would love to see some wrist shots ;)
Reactions: matzemedia
VC202FanBoy
MULTI ACCOUNT
9/8/22
15
It is a very nice watch, so I found a seller who sells glass, case, crown for 2600 dollars on chrono24. I want to buy it. Most likely, I will use the vs3135 movement, but I got very stressed because it wouldn't fit in the case. Do you have any idea what clone mechanism is best for Gen 3035 cal? Also I want to use the original datewheel.
FaberNewBuilder
71
29
Do you know the reference number of the case?
