Fire damaged omega seamaster - partial resto
Mattjames84
DO NOT TRADE WITH ME
8/5/19
247
60
Well I plan to rebuild the gen movement, all the plates and bridges are still good
mrnoahj
1,291
172
Conus
Wow, really neat! Good luck making this all work, perchance, the original owner may like to recapture once completed. Awfully neat if it worked like that!
Mattjames84
8/5/19
247
60
Well Dusk was the owner of it. Sad the tragity that happened to his families house which was how it wound up the way it was. He may want ot back, and if he does I'd gladly work something out with him.
Mattjames84
8/5/19
247
60
Yeah, soda blasting might have worked but iv plenty of time on my hands and the things I'm doing seems to be working nicely, I am by no means a pro at any of this. Just trying to revive a watch so it doesn't get parted out and get some enjoyment out of it, plus with all the paperwork with it what more can you ask for?
Reactions: Raddave
k4jun
Ω Section Moderator
2,945
1,235
Mattjames84 Afair the melted thing is nylon suitcase - are you considering a bath in a mix of hydrochloric acid and acetone? Or even start with the acetone only. Not sure what this suitcase was made of, but I would have tried to dissolve it before any mechanical cleaning.
Usernametaken
1,480
733
Ok so this is just awesome
Sent from my iPhone using RWI
Mattjames84
8/5/19
247
60
I tried acetone, that didnt do anything, I tried boiling it also, that didnt do anything either.. didnt try hydrochloric acid. I thought th at was for dissolving metal? I dont think I'd be comfortable using that unless iv used it before, which I havent
Mattjames84
8/5/19
247
60
I probably be snowed in for a bit, so I should have the bracelet looking decent in the next couple days
Reactions: watchlover128
Mattjames84
8/5/19
247
60
Oh I forgot to mention I need to find a crystal, any good aftermarket ones?
sn95
572
171
actually there is a better way , take it to a shop that does metal working , have it blasted with dry ice
that's actually very interesting and a perfect solution as it's non abrasive. Might be hard to find a shop that uses dry ice.
Raddave
Administrator
66,247
17,256
not really . any shops that do injection molding mold repair should have access to them , ive worked in plastics for the past 25 years , you can get degraded plastics offf a mirror finish and not damage the finish with dry ice
sn95
572
171
That makes more sense, I was thinking your old school CNC machine shops that work with aluminum and such, they have hard times doing a tumble finish/ time saver finish sometimes lol
Raddave
Administrator
66,247
17,256
well with the dry ice temps , it crystalizes the plastics , and it just flakes off , with the CO2 pressure
Reactions: sn95
Nikosaldente
809
280
DON'T USE Hydrochloric Acid!
It will corrode the Metal Parts!
You may use Nitro Thinner or White Spirit!
Both will dissolve the Nylon parts without harming the Stainless Steel Bracelet!
Try white spirit first!
Great job so far!
I look forward to seeing your update!
Cheers!
