F... crown problem
watchlover
1,199
What coop said is correct.. However, if you have not applied any glue to it:
If you did not glue it yet, unscrew the crown from the stem, put some glue there, then screw the crown back into the stem
NOTE: Remember how 'deep' the crown sits in the stem, so you don't screw too much into the stem, and make it shorter/longer than normal :D
there is some margin for error, but being safe is better :D
NAVIGATER
578
Just as other already said ger yourself loctite and it is ok. Than put some loctite on the stem, put the crown back on the stem and wait and it is ready to go again in the movement. Dont forget to push the stem release butten when you put it back agian in the movement:
Greetings Navi :wink:
coop
OG member in the Lou
3,517
67
St. Louis
Loctite is a tread lock compond. Blue and Red are the most common. I would use blue, if you use the red you have to heat it up to break the bond.
coop
3,517
67
St. Louis
Super glue gets brittle and could come loose. An epoxy of some sort would work well.
piratedzeus
2,504
Ok... we had some locktite... blue.. :)
says solid in 3 hours... wait wait wait :p
NAVIGATER
578
Perfect.
Problem solevd 8)
rogerwine
600
Great job gents!! This thread is what this forum is all about. Members helping members. You guys took a lot of your time to help and piratezeus was very patient. Damn this makes me feel GOOOOOD......
Rogerwine
piratedzeus
2,504
ALRIGHT!
Watch works perfect again...crown feels "fixed" now ! :)much better than yesterday... it justs work well :)
THANKS
I used the chance and removed the whole movement out of the case... could have already used my glow inc poweder...
kdo2milger
4,664
274
:( Awwwww.....I thought this was another flaming thread on the dealer for selling you a broken watch :roll:
j/k
Good Job Guys!!! that was some serious 911 action! [smilie=glasses2.gif]
Niko
910
And to think that us guys in the Southern Hemisphere were asleep while this operation was going on!
