Click bezel
bazzino
270
17
Hi to everyone, I have a non gen costruction bezel assembly of a Rolex case. When I turn the bezel it doesn’t make any click. I disassemble it but now I don’t know which piece I have to buy for make it sound. Anyone could help me?
I attached a photo of the case
bazzino
270
17
But I don’t know which piece buy because it’s not gen costruction
tripdog
Super Moderator
22,670
18,250
Take a 1.8 mm diameter spring bar, cut in half - including the spring inside.
Remove the spring, cut it so that it sits level with the top of the hole in the case - the spring shouldn't stick out of the hole. Remove the 'nipple' from the end of the spring bar, place it in the hole in the case, but with the smaller end pointing down - the smaller end is what went into the holes in the case, now you turn it over and place it in the spring.
Assemble the bezel, if the click is too soft/weak, either cut a piece of spring slightly longer, or stretch the existing spring a little to lengthen it.
Reactions: merlix and bazzino
bazzino
270
17
Thank u very much friend, is this the only way?
tripdog
Super Moderator
22,670
18,250
I've never seen a click spring & nipple for sale anywhere, so yes, it may be the only way.
