Cleaning with Cape Cod
faberjay111
2,738
I would like to clean some of my watches with Cape Cod cloths.
Do I have to tape off the areas that are not polished?
For example, I want to clean the bezel of a Pam 192. The rest of the watch has a grey (PVD?DLC??)finish. Should I tape off these areas...along with the crystal.
Ca I also use a Dremel to do polishing? At slow speeds? With what attachment?
Is there a tutorial I can go to?
Any advise would be appreciated!
Thanks!
jamesfl
340
It means he subscribed to the thread so that he can follow the answers.
I think I will do the same.
investinwaffles
665
Cool..I didn't know one could do that. I will find out how!
Thanks
Click "thread tools", at the top right side of where the thread starts (below the RWI headers).
Then select "Subscribe to this thread" ;)
EDIT:
I have no idea about cape cod though :unsure:
tranzmizzion
1,598
EDIT:
Yup that usually woks.... not on tapatalk tho. You have to post in the thread in order for it to show up in "participated" threads
D
d4m.test
Guest
A cape cod cloth WILL turn a brushed finish into a polished finish, so taping off brushed areas is definitely a good idea. I would assume that the same would apply to PVD/DLC finishes.
wtch
27/5/12
77
be careful with a dremel! it can do a lot of damage! only skilled persons should use it on watches! cape cod is good for polishing like stated, and yes, taping is a must. :)
set2374
1,714
44
A professional would remove the bezel and crystal and dismantle the bracelet before getting happy with a Dremel. Unless you have the hands of a brain surgeon, I would stick with hand polishing.
ViperGTS
1,111
127
im not too familiar with cape cod......you're saying it can be used to remove scratches from polished surfaces? like my breitling ProII bracelet?
does it need any kind of polish compound?
trailboss99
Head Honcho - Cat Herder
Administrator
42,611
13,479
Nope, the polishing agents are embedded in the cloth.
