Changing Overseas Strap
tats
783
14
Hey all - maybe I'm a dummy, but I just cant seem to remove the rubber strap on my overseas.
I've removed the lug screws but am stumped after, nothing seems to work. I found this thread on a gen but still am stumped.
Any suggestions?
Here is what I'm talking about
tats
783
14
turnsout I'm just a baby and had to push REALLY hard to get the pin out between the lugs :facepalm:
WingNut
Brig Warden
4,001
1,235
Are you unable to push the pin out?
Maybe a small bit of penetrating lube to loosen it?
***posted after you got it out***
Definitely a bit of lube for next time...
Hyjynx
Put Some Respect On My Name
28/9/13
3,510
523
I'd be interested to know what you're replacing the rubber strap with. I'm not quite enamored of mine.
tats
783
14
Yep couldn't get the pin out, and it turns out my leather strap doesn't fit, the lug holes aren't lining up :(
tats
783
14
I picked up a leather strap of a M2M that was on what seemed to be the same model overseas. But I sent the strap along with my watch to Prof for some AR and to see if he could get the strap to fit and he wasn't able to either.
I think I'm going to look into getting a leather strap made using the rubber as a guide...
The AR however looks AWESOME
WingNut
Brig Warden
4,001
1,235
I had the same problem with my Deepsea...ended up tearing thru the leather trying to force it...ended up trashing it and put the bracelet back on...saved the clasp tho...I was bummed as I think the leather looks sweet.
Mikey101
383
Is this the jjf version of the overseas, I tried doing the same thing and the screws on the lug came out easy(two tiny ones on each side) but they must be for decoration as the strap is firmly in place.
Sent from my iPad using RWI
Dj3381
590
90
Hi there guys
I am buying a gen VC leather strap for my JJF Overseas 47040. Any views as to whether it will fit?
Thanks
Keylog74
14/6/13
3,849
1,680
Hi there guys
Thanks
Yes it should fit. i have some photos around showing the rubber misurements
Dj3381
590
90
Thanks mate. I have already paid for it (EUR 350 at AD) and I am picking it up in a week. I will post photos. Hopefully, it will fit well!
Dj3381
590
90
Yes, I bought it in black. I am having fitted soon (together with a 2xAR prof crystal)! Will post pics.
PlastikMan
2,110
13,272
Hello... it’s an old threat but I am wondering whether there’s photos of the gen strap. Considering adding an Overseas JJF to my collection.
