Cartier Tank Saphire Fell Out Of Crown
kerriganonno
19/7/24
13
Ive had my tank for a couple months and it’s been working great but I just noticed today that the sapphire fell out of the crown and I have no idea where it is. How should I get this fixed? Go to a watch repairman? Or should I order the part from the dealer and then go to a watch repairman?
Any advice would be great!
eBoy
13,847
22,823
I don't think you need a watchmaker for this. It's probably just plugged or glued in. Should be an easy fix...
Getting a replacement item may be the hardest part. Not sure if a TD can source one or how common those are. I'd try looking one up on Dhgate or AliExpress, but asking a couple of TDs won't hurt as well, for sure...
On the other hand, I can imagine those fall off quite regularly, so maybe it isn't so difficult to source one after all.
eBoy
13,847
22,823
Took me 30 sec to find cheap aftermarket replacements on Google for a Santos... Shouldn't be too hard for other models. Like I suspected, it's a rather common part that apparently falls off quite often. 😂
kerriganonno
19/7/24
13
Thanks for the advice. Yes I talked to my TD - Ctime and they are ordering a new stone from the factory. I’m still not sure if it’s just the stone or the whole crown. But you’re right, I think if it’s just the stone I can probably just super glue it on haha
kerriganonno
19/7/24
13
Fingers cros
oh nice! I saw the same one. I looked a little yesterday but didn’t find it for my model but I’m betting that it’s out there. If the factory takes a while I’ll probably just do that.
Did you have yours fall out? Or just found one for your model?
Kerbus
1,357
825
FL
This is the Cartier equivalent to the crown falling off a Rolex clasp. It’s good you can get a new one
what glue should be used for this?
eddieo
lifelong Masshole
259
179
Massachusetts
Actually, I'd say it's the equivalent to the crown logo falling off a rep Rolex winding crown, which has happened to me. I'd love to find a replacement, and I would use super glue.
Kerbus
1,357
825
FL
Regarding Rolex crowns,I have found the cap of the crown of Eddie Lee Datejusts come off I super glued it but it will never be the same
I hope Raffles crowns work on all Rolex reps
Reactions: eddieo
