doctorron
once you have the parts it is easy, and pete 2528ca recently gave some details on how to do this, in words that were better than I could use to describe:
"the hour wheel and cannon pin sit under the dial. it is fairly easy mod, especially if you are changing a dial anyway.
the hour wheel basically falls off if there is no dial in place. to remove the cannon pin however, you must remove the plate over the keyless works and remove the gear closest to the cannon pin. just be careful not to unlatch the v spring in the keyless works because it is a beeotch to put back. then once the gear is out, i put the plate back on to hold the keyless works snug as a bug, and use a hand remover to lift out the cannon pin. you should feel a slight pop. then push on the new one, again hearing a click, and reverse the keyless works part. slide on the hour wheel, put on the dial and then "Bob is your fathers brother."
http://replica-watch.info/phpBB3/viewto ... in#p394895
Vacuum's tutorial on RWG is definitive, but you need some extra details above from pete
http://www.rwg.cc/members/index.php?sho ... &hl=cannon
