BP Sea-Dweller 16600 re-release with VR3135
mclarendude
31,024
39,274
ATL
lol, so your saying I’m wasting money getting a gen bracelet? 🤦‍♂️😂
Only worth it if you're getting a Gen non-solid endlink one and even that is more ratty that the one you have!
Mjh2k4
1,147
1,805
Southeast England
Yeah haha. I’ve got a couple 4 digits but figured the rivet hollow bracelets would be light as fuck anyways. But I guessed with the move to the 93 series and only hollow end links the clasp would be a bit more robust.
bowtiefanatc
1,293
1,418
Gen insert, gen crown ( if you so desire), gen hands and call it a day.
bowtiefanatc
1,293
1,418
Has anyone taken the bezel off one of these newer ones yet? Just want to know bezel construction.
AyrtonThames
15
Hi everyone, just wanted to share my journey with the BP 16600 I bought some months ago from another forum member, great value for money and a true workhorse…
…BUT since the very first day on my wrist the crystal profile, completely off compared to gen, started to bug me.
In the end, after some measurements taken without taking the watch apart, I decided to pull the trigger on a secondhand gen crystal and try to install it by myself.
Of course, things didn’t go as smooth as expected: gen crystal has a completely different profile compared to the BP one, therefore neither the gen nor the BP gasket would suit… in the end (after more detailed measurements taken with the watch dismantled) I tried with another gasket that suited perfectly the case but was a tad smaller on the inside to lock the crystal in position (for the DIY fanatics, outer diameter is 30,4 mm, inner 29,4), so in order to not lose the crystal any time I rotated my wrist I tried locking it with a very thin layer of silicone between crystal and gasket.
I know, sounds like blasphemy… but in the end, it worked!
And after all those words, I would like to share with you some photos of what I think is (AFAIK) the world’s first BP 16600 with gen crystal installed (also with LEC detail)!
In some pictures you can see some silicone smudges near the crystal, but in person are barely seeable up close, on the wrist are pratically invisible.
Now it's time to address the wrong code clasp...
kiasunkiasi
390
409
Malaysia
interested in getting a Polizia
apart from grinding with keys inside pocket, what can we do to make the 16600 look more used? bring to beach and let it get some scrathes?
Reactions: Reaps
AyrtonThames
15
one trick could be to put the watch inside a clear plastic box half filled with sand, pebbles and some screws/bolts and nuts and to rattle it in order to get various scratches, some lighter and some deeper...
I would also suggest to put some masking tape on the glass in order not to risk to scratch it
oh_chesteroni
15/2/25
Does BP still make the non-polizia 16600? Was on Andiot's website and only saw the polizia version, which I'm not too fond of.
kiasunkiasi
390
409
Malaysia
Or, just wear it everywhere 😉 mine turns 8 this year, and still going strong.
thanks for the suggestions on sand pebble screw and nuts
I do usually wear a watch where ever I go after receiving it, just try to make it a little bit aged considering 16600 is long discontinued and shouldn't be spanking new :ROFLMAO:
