As is smaller it fits however you have to properly attach it to the movement because does not get fixed by the case inner sides.
I bought that spacer at rafflesdials.com
Oh yeah and also... IMO, a better alternative to cartel 5513 is the BP vintage 5513 (which is lesser known). Apparently from what i have gathered, the BP's mid-case is the same as cartel... BUT the BP vintage has the following advantages:
1. The BP vintage 5513 has WAY better-looking hands (I got OCD for hands). Cartel 5513's hour hand screams fake to me
2. The BP insert looks prettier to me. Cartel insert font doesn't look like any of the gen inserts, but the BP insert looks more like a gen service insert with thin font
IMO, the hands alone is worth considering a BP vintage 5513 over a cartel 5513. I can't stand ugly sub hands - instant tell to me
you can find out more about BP vintage here:
http://www.trustytime.biz/index.php?...43dcd51ef7c501
(please note that the website is for your reference only because trustytime is not a TD in RWI. However, any of RWI's TDs can source a BP vintage for you)
Is it possible to change the crown on the bp modell too? or is there no need to? What is the case different to cartel and jkf?
Good point! Is there a 5513 case which has the correct diameter for a yukidial (without spacer)?
Cool, now i understand!
Which dial diameter would work fine without spacer, without cutting off to much of the dial?
The only advantage of the Helenarou case is that it has correct crown stem hight as it takes the eta 2824. Some people see the lower crown hight on the cartel cases as a dead giveaway. Unfortunately The helenarou case lugs and crown guards are not as meaty and not quite the right shape. I guess it depends on your budget
How about the Ruby case or the MQ case? Do they have the correct crown height? Of both cases the shape of the crown guards and the lugs seems to be more like that of the original case than those of the Helenarou case.
