In my subjective opinion...
1. MBW = wrong crown / stem / tube height. Stock shape is better than stock Cartel, but they are rare and discontinued
2. Cartel = wrong crown /stem / tube height. Lugs and fat crownguard needs reshaping. Good for budget build
3. Rubyswatch vietnam case = correct crown / stem / tube height because it can take gen movement. Might need some minor lug / CG reshaping. Excellent quality and members/modders on rwg have vouched for them (e.g. rolojack). Some members say it is the same case that is supplied to Phong / MQ
4. Helenarou = correct crown / stem / tube height because it can take gen movement. BUT lugs have uncorrectable weird profiles and they are on the fat side
Conclusion IMO
- on budget = buy cartel
- need accuracy / superfranken with gen movement / have OCD for wrong crown/stem/tube height = buy rubyswatch case
how about the cartel 5513 case. i read, that the dial is very large, hard to find a fitting dial for that, right or wrong?
Sorry, for that question, but I need a link or more information where to buy a cartel case.
Be so kind to help me.
Yes but you can put a Vietnam dial on it, I fabricated a dial spacer and dial feet for the ETA 2824 movement I used and is perfectly centered.
Very nice, how do you fix the feet on Vietnam Dial ? With Epoxy ?
Conclusion IMO
Where can a Ruby's case be purchased - Google search not finding it.
Hello pompompurin my hero, I think same as you regarding Ruby's cases, are the best of the lot beside Phong/Jensen/Vintagewatchmaker. I've been seeing and comparing pictures quite a lot and if the latter are the same as Ruby they may be slighty reshaped/modified, I don't think they are exactly the same - but maybe is the light and angle of the pictures.
Hello and welcome lamuken it takes not too much effort to modify a Cartel case and the results are really convincing, using some other parts as the Athaya Crown and WSO bezel plus a Vietnam dial, you can see what you can get… look at my Cartel based 5513:
i will try this way, what do you use for the feet ?
Thanks !
Great informations, thank you!!!
But i'm still confused. I read, that the diameter of for example yuki dial or other gen like dials have a 26mm diameter and the dial of the jkf 5513 is 29mm. So the new dial would get cut, wrong?
Where to get that dial spacer? Could you please psot the link to the dial?
Hi, is it easy to change the crown to an Athaya Crown?
Everybody is writing about WSO parts (bezel), is there a link to wso?
thank you!
