- 7/9/06
- 890
- 50
- 28
Hey everyone. Which dealer is good with parts? Namely a case set compatible with the 4130 movement.
Doesn't even need to be branded.
Cheers![Clinking beer mugs :beers: 🍻](https://cdn.jsdelivr.net/joypixels/assets/6.6/png/unicode/64/1f37b.png)
Cheers
Sure if that's the best spotI think tech and vintage sections are the places to make these questions, lots of knowledgeable guys there. I can move it there if you wish.
May I suggest creating your own thread?Hi, @Feefo . I am checking for a Pam ss caseback . Can you suggest me someone ? I think I’ve read in appropriate section but they sells only cases, dials, bracelet, straps and hands . Thanks a lot . Greetings from Italy .
Cheers![]()
Seems anyone seeking 4130 case set is out of luck. Drawing blanks every which way.
Minimum of two order.
Bt Factory Watch Case For Rlx 116500 Fit 4130 Movement,904 Steel Ceramic Bezel Aftermarket Watch Parts - Buy 904l Stainless Steel 4130 Watch Case 904l Watch Case Product on Alibaba.com
Bt Factory Watch Case For Rlx 116500 Fit 4130 Movement,904 Steel Ceramic Bezel Aftermarket Watch Parts - Buy 904l Stainless Steel 4130 Watch Case 904l Watch Case Product on Alibaba.comx.alibaba.com
