Start time is the best aftermarket imo. That, plus there are not that many aftermarket hands that fit 3135/3035s.
The only thing you would be to do is the match the lume color on the hands.
If you’re OCD like I am, check the edges with a 10x loupe and check the pointy bits and make sure they’re not completely sharp. I sand mine very gently to slightly round the ends. This is a hit or miss tho. I had some that shows up perfectly rounded ends and some show up that are sharp as knives.
You can also have the lume slightly off color since they do tend to change colors much slower than the markers.
The Pearl is a bit tricky. You can buy a gen tritium Pearl insert for a few hundred bucks but I went with my method of holding the Pearl with steel tweezers and a lighter. Hold the Pearl up to about an inch away from the back of it for a few seconds and then flip it over so the clear Pearl (make sure it has a sapphire crystal cap and not plastic or nothing at all) for a few seconds and you get a nice brown color.
