Beginning my 6538 Build…
DeLoMan
269
689
Hi all. The journey has begun. I’ll be using this thread to document my 6538 build. It’s been several years since I last built a replica, so it’s fun to be getting back into this. So far I’ve been working on a Raffles’ case, and I must say for $50 shipped it’s quite a bargain. Sure, the dimensions are a little off, dial size is 28mm-29mm, etc, but for the price I can’t complain. I bought a spare for future projects too.
So far I’ve drilled the lug holes, sanded and brassed the bezel with a blowtorch, thinned/reshaped the case a bit, softened the edges, sanded the insert and chewed that up a bit, and gave it all a good tumble in a box full of screws to help add 60+ years of wear to it. Trying to make it look natural. Will it ever be as accurate as if I spent thousands on a build with a Vietnam case? No.
Here’s where it’s at so far. Next up will be an NH38 movement (basically an NH35 with no date mechanism), a gilt dial from manodeoro (the dial pictured is a waterslide decal attempt I tried), and Tiger concept hands with a lolipop seconds hand. Looking forward to the end result.
Winni1611
1,590
2,328
As said, the case is fine. Not shure if someone would leave these deep dongs on his gen. In my Phantasie he would try to polish them out as good as possible (therefor I like the overpolished look).
Thats great on building vintage watches. Everyone has his own Story behind it.
Waiting for final results 🤩
DeLoMan
269
689
I’m sure I’ll hit it with a cape cod cloth a few times before the build is done to polish it while still leaving enough wear and tear to keep with the heavily used tool watch look.
Reactions: Winni1611
Karbon74
Pika Factory
11,879
24,549
EU - Kalos Region
cape cod is not going to do much to this 😅
I would recommend some gradual buffing 800-1000-3000-5000-7000 grit
It will still leave the marks, but it will give the look of someone who cares for the watch
except of course if the core concept is the "I don't care" tool watch look
DeLoMan
269
689
I was having a few doubts about my case shape after I had done some filing on it (I know we are ALL perfectionists here about our own work) and was trying to compare to some gen images. Most of the pristine gens have longer lugs. However, I came across a YouTube video of a well worn and heavily polished gen, and the shape shocked me. Pretty darn close to what I got Raffles shape to be, just by coincidence! Obviously the crown is a bit higher on the gen than on the Raffle case, and the bezel teeth need some wearing down, but not bad if I can say so! Looking forward to finishing this build once I get my @manodeoro dial.
I also started looking at strap options. Not sure if I’ll go with a rivet bracelet, nato, or a heavily aged leather strap. Here’s a leather option.
DeLoMan
269
689
I dig that weathered leather strap Where is it from?
Thanks! It was a ”roll of the dice” AliExpress purchase for $10. It looked good when it arrived but was too shiny, so I did a few quick passes over it with a red scotchbrite pad to get it to what you see. I’m not entirely sure if I'll use it on this build or another one.
Reactions: 369mafia
Tictac789
Time is precious but cheaper with reps.
251
243
Hello,
Nice base you have here.
How did you reshape the case? a dremel ?
Thx
Karbon74
Pika Factory
11,879
24,549
EU - Kalos Region
Thanks! I used small hand files and various grits of sandpaper to polish the file marks.
oh man. I started out with hand files but it takes ages and my hand was flying all over the place. Personally, I feel I have more control with a fixed dremel and working the case around
DeLoMan
269
689
I get that. I’ve used both, but a Dremel can sure take too much off too fast. But on a $50 case, I guess it’s worth the risk! Haha.
Karbon74
Pika Factory
11,879
24,549
EU - Kalos Region
yeah, that's why I move to a 300 or 400 grit sanding drum quite fast once I got the gross shape
I still do chamfer, plus final gradual buff and polish by hand though
DeLoMan
269
689
I’ll make note of this for the next one I make. Will save me some time and sore fingers!
Reactions: Karbon74
Tictac789
251
243
I'm thinking about reshaping a 50$ case for a sub Tudor. I'll buy a dremel stand for sure.
Is it possible to do for a beginner? Or It is only for pro's?
Thx
Reactions: vanheden
Karbon74
Pika Factory
11,879
24,549
EU - Kalos Region
Thx
it's 50$ + cost of dremel and station
worth trying. at worse you lose 50$ a few times
Cheap for lots of fun. By the hour, for entertainment, it beats dinner and a movie 😅
DeLoMan
269
689
I got a beautiful dial in today from HelenaRou/MK, and went to work weathering it. Then did the hands. Also aged a Tiger bezel insert. Hopefully assembling this weekend!
Dial as received:
Dial and hands after aging:
A quick glimpse of what it will look like in the case:
Really happy with how this one is coming along.
