Aquaracer custom build. Help
sirioñoco
11/12/22
11
Argentina
Hi! I'm a huge quartz watch fan. In my collection i have severan gen and replica watches with brands such as seiko, longines and Tag heuer.
I've recently bought a second hand very well made tag heuer aquaracer rep. However when i opened to replace the battery i noticed that it has a seiko vj42 movement which is very very cheap. Since the original aquaracer has a Ronda 6003d movement and it cost like 30 bucks in aliexpress, i need to know if the vj42b movement could be replaced for the "original" one.
Thank you very much!
Thatwatchguy
7,275
4,863
We will need much more information my man, model, case size pics etc?
sirioñoco
11/12/22
11
Argentina
Hello and thank you for your answer. The model is a Tag aquaracer 43mm.
Even though it runs fine, my desire is to upgrade the movement. I´ve cheked with trusty but they dont sell spare parts. So my best option is to buy a movement from aliexpress. So i have to find a compatible movement with the HOUR/MINUTE/SECONDS hands and try to adapt the display. Any suggestions are welcome.
Best regards,
eBoy
15,306
25,951
The fact that the watch has a date complication makes things... Well.. even more complicated than they already are! Unless the Seiko and Ronda quartz movements have identical specs (which they do not), I don't see it happening without heavy (& costly) modifications!
eBoy
15,306
25,951
PS: You have to consider hands attachment, date window position, & size, date wheel, dial attachment, dial diameter, movement diameter, crown and stem must all be compatible or modified to be compatible.
