Seemingly a new release, though I remember reading that the movement would be a modified 7750. However the release post says the movement is Dandong and that the watch is 11mm.
Have asked to get additional details from some dealers and will follow up.
Translated:
Breaking News!!!
APW+ (Steel King) introduces an exclusive version with the same thickness as the original Audemars Piguet 26331OR Royal Oak Chronograph Mechanical Watch, 41MM. A market-exclusive integrated masterpiece!
Key Features:
1. Custom-developed movement: All functionalities are identical to the original, featuring a 3 o’clock minute counter, 6 o’clock small seconds, and 9 o’clock hour counter.
2. Perfect alignment of sub-dials: The three sub-dials are precisely positioned in line with the original’s center axis.
3. Exact thickness: Matches the original’s 11mm thickness!
4. Power reserve: 42 hours, powered by the highly stable Dandong Peacock movement.
5. Authentic case and strap construction: Follows the exact assembly method of the original, with a sapphire crystal glass mirror that offers the same dual-sided high transparency and anti-reflective effects as the original. The stainless steel case is crafted using original data molds and features top-tier polishing and finishing. Every detail, from the texture to the feel, closely mimics the original, with brushed and polished elements giving it a refined yet bold look.
One-to-One Functional Restoration:
• The distance between the sub-dials, the movement thickness, and all other aspects are perfectly aligned with the original model.
Translated:
Breaking News!!!
Key Features:
