4130 issue with keyless
mrsullivan
Replicaddict
6,041
12,840
Hi everyone
Here I am (again) with a keyless issue :
I just got a Noob Daytona with a detached coronet, and when replacing everything at the end the crown stem just didn't click in.
I'm kinda stuck and need help with these stem removing-replacing phases :
1. I pressed the release button but it did'nt dip in much, so I felt I had to pull a bit harder than usual before the crown came out. Is there a chance I went too hard and broke something (clutch)?
When I try to replace it, the stem does'nt lock in any position. When I play with it though, I can catch the hands and move them, but can't get the movement starting.
2. When replacing a stem in keyless, is it a simple push & click while playing with the crown? Or do we have to always press the release button again while pushing the stem back in? I remember Tripdog giving me this tip when I could'nt push the stem back in a 2824 a while ago. Today I tend to repeat that each time I work on 28xx, but is it the same with 4130?
Thank you all
Reactions: kennygconspiracy
mrsullivan
Replicaddict
6,041
12,840
Oups, I guess I bypassed this thread when searching.
Huge thanx to you KJ2020 for pointing it!
Reactions: KJ2020
tripdog
Super Moderator
22,664
18,232
You need to remove the stem in the winding position with that movement, if not you run the risk of the keyless works moving out of position.
mrsullivan
Replicaddict
6,041
12,840
True, I removed the stem in time setting position, thinking it was the right thing to do as for 28xx movements. That'll teach me to start works without digging into the specifications of a movement I've never worked on. A new lesson in amateur watchsmithing I guess.
I'll follow the hints from red1's thread above and try to get the yoke back in place, and if I'm not confortable I might just send it to a forum's watchsmith. I hope I did'nt break something though.
mrsullivan
Replicaddict
6,041
12,840
Quick update : I don't feel confortable playing with the 4130 keyless yet, so the watch flies to Johnny Depp for a full checkup.
Thank you all for your help ;-)
Reactions: CorinS89
CorinS89
Looking Around
3/9/22
Hi! I’m having the same problem. Did you manage to sort it out? Are you by any chance in the UK and found someone to help with this here?
