Hi guys, my brain is dead now and i cant find a solution so im trying my luck here.
I got an non working omega from a friend to fix. It wont wind and basically wont work.
As i stripped down the movement i fount an open mainspring barrel and A LOT of oil in the movement. i cleaned everything up and assembled the whole movement and wanted to try it out.
It turned out that the joke wont push the sliding pinion to the winding pinion and if it does, it winds a few turns and jumps away again.
I tried another working keyless, i tried another sliding and winding pinion (all from a working spare 2824) and a new blistered stem. but nothing really helps. all other funktions (date and time) working like a charm. also the movement runs great again after a new mainspring plus barrel and a full cleaning and oiling.
