New-ish member shows their junk (6538 case reshaping)
lucadotti
Good evening.
Today I present how it started...
well kind of... I added the rivet bracelet. Aaaaannnd how its going...
I've never been a metalsmith nor do I have any experience moving metal around. I think I've done a fair job a recreating the chamfers of a 6538. I haven't polished them as I am still unsure if it would be very complimentary to what should be a true vintage watch.
As always, I am open to constructive criticism, but if you are just going to be a turd; well, go ahead. You were going to anyway.
Best,
Reactions: rwacc
Specter1000
1,258
610
Cincy area
I don't see anything wrong with that...its a little bit over the top, but hey...each his own. I'd wear it.
Reactions: rwacc
lucadotti
Appreciate your feedback. I am still on the fence of what type of bezel insert I am going to swap to. It won't be nearly as relic'd as this one lol. This was a first attempt; and some might say failure, at a relic bezel.
Best,
kilowattore
13,620
5,823
Chamfers look ok, you did a good job but now comes the difficult part: polishing them without losing their shape :)
For the rest check raffles for a new insert and helena rou for a dial, then you're good to go imho
p0pperini
patr0n h0arder
9,005
30,343
Very nice work, bravo and thanks for sharing. I like a really defined chamfer, so IMO they look great. But they do need to be polished to really look the part.
I also like the OTT beaten up look of your insert, but it does tend to draw the eye somewhat..! So I can understand why you want something with a more subtle finish.
manodeoro
3,831
2,162
lucadotti congrats for the chamfers ... maybe you could use a burnisher to get them polished without loosing ther shape
Reactions: rwacc
p0pperini
patr0n h0arder
9,005
30,343
What is this magical instrument of which you speak sir? At first I saw it as "bumisher" - like The Punisher, but for... bums. But I would like to know if a "burnisher" is a tool that's missing from my armoury of tools - all which I use equally badly.
manodeoro
gunsmoke16610
FIVE-Digit
1,113
1,774
I’d also like to know. I’m hopeful that a alternative to the lapping machine exists.
p0pperini
patr0n h0arder
9,005
30,343
in french : cabron. Used in jewelry and in my case to polished my diamond awl for leathercraft
Okay... Cabron seems to be French for "sandpaper glued to a lolly stick". And their described use is for finishing a surface prior to polishing, which doesn't really seem like what I'd expect from a burnishing tool. But maybe it is. Still, it would be nice to get confirmation from manodeoro that he's referring to sandpaper glued to a lolly stick.
Reactions: deadpan
manodeoro
3,831
2,162
https://images.app.goo.gl/bUARcomR6eS953f69
https://sodimabi.com/limer/249-cabron-plat-3000001023265.html
Burnishers (brunissoirs) are used in jewellery to achieve a really fine polish on soft or hard metal without removing material ... cabron will definitely remove some
There are different sorts of burnishers, made from metal or stone, depending on which material you want to polish.
Engravers use stone burnishers to polish steel printing plates.
I never tried that tool on a watch case but years ago I studied engraving at a fine-arts school and we used agathe burnishers to get perfect "white" areas on the printings.
When you polish stainless steel there's always a really fine texture remaining, whatever sanding method you use ... even with with wet 2000 grade sandpaper then polishing compound.
The texture is so slight you can't see it with naked eye but you can see it on the prints as you get a "soft grey" or "off white" instead of pure white.
So we used agathe burnishers to achieve to get perfectly polished areas on the stainless steel printing plates so that no ink was transferred on the printed paper.
The process was quite long but it worked perfectly ... we used that method on small areas only but I guess it could be use to polish chamfers on a watch case.
I just ordered an agathe burnisher today so I'll let you know if it really works on a watch case ...
Reactions: p0pperini
p0pperini
patr0n h0arder
9,005
30,343
Thank you, as always, manodeoro for the interesting background detail - and potentially another tool for the box. Really looking forward to seeing how the brunissoir performs!
Amaiel
402
101
in this case the real tool are...the hands. Without proper skill and experience the "Cabron" becomes quickly "Cambronne".
p0pperini
patr0n h0arder
9,005
30,343
I think it would take absolutely ages to burnish it with your fingers. And it'd also lead to nasty friction burns unless you did it slowly. Could use a fingernail to speed things up a bit, maybe.
Reactions: lucadotti
manodeoro
3,831
2,162
Possibly a Peggy Sage nail high polisher could be used ... I polish handsets with it
p0pperini
patr0n h0arder
9,005
30,343
I was just joking - about the idea of (literally) using your hands as tools - but now you've gone and turned my nonsense into another handy tip... heh!
Usernametaken
1,480
733
Used to buff my car this way, always looked worse after I was done..(lol)
