New Noob Daytona 116520 4130 clone build thread.
thinwhiteduke
1,053
234
Nate0624 the Easylink works perfectly on mine
Sent from my Mi MIX 2S using Tapatalk
Pardon my ignorance, but I cannot make mine work. For my own education, how exactly does the easylink work exactly?
I mean from your two pictures, I think you showed how to use the Rolex "micro-link." And I know how to do that. I am referring to how I can move the final link along the clasp like we do with our subs. It appears the easy link is not as easy, and would require a tool like the 5-digit subs? Pls enlighten me. TIA!
mui.richard
709
294
First off I'm not aware of a Rolex "micro-link". There are two things happening within the Daytona clasp - the "Easylink", and the three micro adjustment positions.
There Rolex "Easylink" works like a folded half link. It flips open without the need of any tools to accommodate wrist expansion on a hot day.
The three micro adjustment positions is like those you see on any adjustable bracelet clasp, but in Rolex' case the indentations are hidden inside the clasp and would need at least a spring bar tool to adjust.
Which one are you referring to?
https://youtu.be/942TGgWip6U
Reactions: Nate0624
Doc brown
426
165
Does anyone know what size Chuck opener the 4130 noob requires? Is it 29.5mm like the SD43? I need to open this watch.
Nate0624
15/11/16
97
Fantastic. I've been doing that incorrectly the whole time. My Noob bracelet is correct then. Thanks mui.richard Operator error, I suppose.
Cheers Gang.
Sent from my SM-G950U using Tapatalk
Reactions: mui.richard
rolexwatchfan
Put Some Respect On My Name
17/8/13
4,224
799
Instruction manual that came with my GEN:
32,928
59,675
Received my black dial Noob 116500 from TD.
Question: does anyone know if the quick release on the Noob bracelet is supposed to be functional? Mine doesn't seem to work.
Some of those are just REALLY tight. Have you tried any lube? Soak it in WD-40 for a while. Also if you have access to an Ultrasonic cleaner, those things do wonders for reps. First thing I do now with a rep is tear it down and Sonic it for 30 mins. Leaves a crap ton of black silt in the cleaner tank.
Reactions: Nate0624
DJ Woody
193
42
London
I just tried it on my Noob, it worked... opened from short to long, but required WD40 to go from long to short... wont try that again in a rush....
thinwhiteduke
1,053
234
Thanks, mui.richard . It's the latter I was referring to. Yes, as far as the easylink or comfort half-link is concerned, I knew how to do that. It's more of the latter, and I just wished Rolex would have adopted the sub concept where no tools are needed to move from slot to slot. Again, thank you!
mui.richard
709
294
Thanks, mui.richard...It's more of the latter, and I just wished Rolex would have adopted the sub concept where no tools are needed to move from slot to slot. Again, thank you!
The Sub's clasp is called the glidelock and yes that's a lot more convenient and requires no tools. But with the Easylink, once the bracelet is fitted to your wrist I just don't see much need for the glidelock anyways.
See, the glidelock is designed so that you could easily wear the Sub over a dive suit without using tools for adjustment. But I doubt anyone would need that for a Daytona or an Explorer.
lcsrep11
203
Peoples wrists expand and contract in hot and cold climates thats what the easy link is for.
Reactions: stufuse
32,928
59,675
The Easylink is a 5mm change of length. Changing a pin position on the clasp is a 3mm length change. Glidelock offers the greatest flexibility with 2mm adjustments. It's my first choice on any bracelet, correct to model or not. I use a rep Glidelock on my gen GMT. I suffered for years with an ill fitting bracelet with a gen flip lock. No more.
Reactions: MrBeasy
Princewilliam
1,969
1,070
Mine can swell 1/4 to 1/3 of an inch just throughout the day, I’m always adjusting my glidelock, couldn’t live without one now.
Reactions: KJ2020
thinwhiteduke
1,053
234
Yes, I guess I stated rather poorly what I wanted to say all along: for such a pricey piece, why didn't Rolex use a glidelock for the Daytona? Yeah yeah yeah the Daytona is not for diving, but that reasoning misses the point: the glidelock was perfect as far as comfort, convenience, ease of use, safety, etc and you go back to a primitive "tools-needed to adjust" clasp? It's counter-intuitive.
Reactions: KJ2020
Rep Enthusiast
31/3/18
61
Hi, first of all, you have to realize that rep buyers are not the main clients of rolex watches. :)
In addition, however, the locks are of different lengths and, in addition to the functional aspects, the aesthetics have very likely spoken against putting a longer lock on a relatively delicate watch.
no hard fact, only my opinion
lcsrep11
203
Your point is ridiculous. The glide lock is for quick adjusting to wear over a wet suit as divers need to change the size frequently. Unless you plan on wearing a wet suit to a motorsport event or the office on dress down friday every week then i think your good to go with the Daytona micro adjustment, most other watches don't even have this feature. I wouldn't go diving wearing my Daytona and the micro adjustment works perfect for small fluctuations in wrist size due to climate temperature changes. I had my watch sized at the dealer 7 years ago and never touched it since. So unless your planning on gaining / loosing 150lbs I think you can leave your tools in the tool box buddy.
32,928
59,675
You make assumptions about what others like or need. The Daytona "micro adjustment" as you call it does NOT work perfect for small fluctuations in wrist size due to climate temperature changes FOR EVERYONE. If it suits you, great! I will be using a Glidelock on my Daytona, thank you very much.
The Easylink is a 5mm change of length. Changing a pin position on the clasp is a 3mm length change. Glidelock offers the greatest flexibility with 2mm adjustments. It's my first choice on any sport model bracelet, correct to model or not. I use a rep Glidelock on my gen GMT. I suffered for years with an ill fitting bracelet with a gen flip lock. No more.
