- 9/11/14
- 34
- 0
- 0
After months of research, reading and digging throughout three forums, decided to pull the trigger on two kw pams (382 and 438).
Well, they arrived today; so the bronzo came with the minutes hand popped out, but seems the watch is winding and moving well (seconds and hours hands), so probably an easy fix.
Different story with the 438 ceramic one; all hands in place but, 4-5 minuets after the time is set, but hands (minutes and hours) stop working. This watch also seems to be working as seconds and watch keep turning and ticking.
I assume the first issue is more common but, is there anyone out there that experienced the second one? I would like to hear from you, hopefully you are willing to share.
I am working with the TD, to see what can be done.
I know there are some Canadian, Toronto members, I appreciate if you could recommend some local watch maker. Your PM is appreciated.
Any help, suggestion highly needed and appreciated!
BTW, the watches look stunning .....wish they worked too
.d
.d
