Good sale on San Martin GMTs (about a week left)
Karbon74
Pika Factory
12,355
26,110
EU - Kalos Region
I made this instead for about $175. I've been on an nh34/5 kick lately. They are so easy to put together. This case set is also hella nice - was around $100.
I'd love to have the link to the case please
37,544
80,340
Just found this amazing item on AliExpress. Check it out! $49.60 20%OFF | 38mm Watch Case Sapphire Crystal High Quality Sterile NH35 Movement Automatic Mechanical Luxury GMT NH34 Fits 28.5mm Dial
It's up a few bucks from what I paid, still worth it though
37,544
80,340
Have you ever thought of shaving it down a bit ?
I took one bezel off to attempt that but the construction was not like anything I've seen before. The rehaut, crystal and bezel came off in one piece. The rehaut was apparently glued to the bezel and held by a small screw while it cured. Someone overtightened the screw and sheared the head off. I don't think it would have mattered, as the joint between the rehaut and the bezel was so tight I couldn't get a razor blade in to even begin to separate it. No way to replace this crystal, good thing it's saphhire.
  • Wow
Reactions: Karbon74
Karbon74
Pika Factory
12,355
26,110
EU - Kalos Region
clearly they need to cut corners to get to that kind of price. The case is very nice though, and I don't mind the deep rehaut either.
and where did you get the GS dials? same shops?
37,544
80,340
Sometimes, but there are tons available. Some shops won't do logos at all, others offer with or without. Just look for details in the listings.
Reactions: Karbon74
Karbon74
Pika Factory
12,355
26,110
EU - Kalos Region
thanks I found some.
Not the nodate sunburst one though.
I will keep looking
The birch ones are mighty fine
Reactions: KJ2020
37,544
80,340
I will keep looking
Look in this store - search "nh35 dial" (Search in this store)
Excellence Watch Accessories Store
Reactions: Karbon74
37,544
80,340
I will keep looking
Note that the nh34 dials have a larger center hole (just like Rolex GMTs) so if you want to use an nh35 dial for a GMT you can drill the dial center hole a little larger. I did that on the blue dial GMT.
eBoy
15,419
26,165
Holy crap... This brand makes some nice looking timepieces. 😲 I had noticed the name a few times on AliX and mentioned on Reddit as well, but I wasn't aware of the excellent craftsmanship they have. Will need to take a closer look....
eBoy
15,419
26,165
I have 4 San Martins, 1 Cronos. Loved them to bits. I still wear them occasionally, when I don't wanna attract any attention or I know I'll be in a bad neighbourhood.
Don't want to turn this thread into a social science / political excursion, but just as a quick off-topic commentary: It’s sad that we have to take things like that into consideration, in certain cities. But here we are at the end of 2023... 🙄
  • Sad
Reactions: Reaps
Karbon74
Pika Factory
12,355
26,110
EU - Kalos Region
this one practically has your name on it
Just found this amazing item on AliExpress. Check it out! US $274.57 39% Off | San Martin 38mm Vintage Men Watches Classic 1957 Retro NH35 Automatic Mechanical Toolwatch Sapphire Waterproof 100mm Luminous
Reactions: eBoy
