Yachtmaster recommendation needed
Alex1976
1,363
197
Feefo
20,506
54,076
My 2 cents, tedf is not as known as clean, but iirc it's a spin-off of vsf, it also has its movement, which is generally recognized as a very good one.
On the other hand the VR movement clean uses is more easily replaceable if something goes wrong.
Can't speak for finishing quality though, clean cases are usually very well done. Tough decision. I'd do some research on this ted-factory to check if overall quality is up to clean.
Rx4Time
Supporter, Panerai lover
12,343
11,926
While I think ultimately you would be happy with either one, consider this. The TEDF has additional weight in the mid case so it's overall weight will be closer to the genuine's. The VS movement is considered the best movement out there. Replacements are not as readily available as the VR, but just about everything in it is compatible with genuine parts so it could be repaired should an issue a rise. I can't speak to the finish quality. Personally I am not a fan of any of the Rolex with the rubber bracelet.
Reactions: Alex1976
Yacht-Monster
The entertainer previously known as Roughwatch
1,201
942
The Eternal Winter
I’ve owned almost every variant of the rep and although the TED factory is essentially a VSF with extra weight, it’s still around 50g less than the gen. I’ve ordered the Gold factory version as the weight is closer but it does use a VR movement but that doesn’t bother me. Their 126655 tungsten rep is superb so I’m hoping for the same with their 226659 rep.
Alex1976
1,363
197
Interesting, never heard of the Gold factory, will check it out and thank you for the feedback.
Reactions: Yacht-Monster
Alex1976
1,363
197
Now not sure if going with VSF, Clean or Gold Factory......................after some research VSF seems to be the best option if weight is not a priority??
26,151
Do you care about weight?
Yes? Gold or TEDF
No? VSF
Personally for me, the weight is a gimmick. It makes the watch more uncomfortable to wear. So I would go VSF.
Reactions: Alex1976
26,151
How about a CF yatchmaster?
CF and VSF to me same tier. Depends on what you value. I think CF looks better overall. VS crystal and movement better. But imho they both kinda the same quality.
Reactions: Alex1976
Storm.
7,975
11,496
Guys what's the point of the whole "I want the weight" thing.
Nobody is gonna rip your watch off your wrist and say "hmmm not gold weight"
I have a 116518 and the steel weight makes the watch so comfortable as it's barely noticable on wrist
Yacht-Monster
1,201
942
The Eternal Winter
I see your point and it’s probably a personal preference but you could say the same for rep movements, especially with Rolex clones as nobody’s going to rip your case back off. For me it’s about getting the rep as close to the gen. I had a VSF white gold plated, waterproofed and serviced, but after handling the gen the lightest of it just threw me off each wear.
Yacht-Monster
1,201
942
The Eternal Winter
Yes? Gold or TEDF
No? VSF
TED is VSF according to the TDs. Some members have speculated why but it’s just their tungsten label for the same watch.
26,151
I don't wanna be that guy, everyone has their own opinion,
But clone movements serve some kind of purpose for looks, especially stem/crown height, hand stack, cannon pinion height, correct thickness, for chronos, correct subdial location, etc.
Then you go further and you see that clone movements allow for the feasibility of swapping gen parts into it easily.... for example, in the Daydate frankens, it has been really hard to swap gen daywheels and datewheels into 2836 without some kind of custom overlay and shaving those wheels.... whereas hopefully the new VR3255 allows for a direct swap easily
Whereas added weight is just that, a gimmick, added weight
Reactions: Storm.
Yacht-Monster
1,201
942
The Eternal Winter
I see your point and it is a personal preference for sure. For me the weight isn’t a gimmick as the whole point for me is to get it as close to gen as I can. As mentioned, my VSF irked me even though I put a decent amount of money into it. Maybe had I not handled the gen it wouldn’t have been the case but that’s how I feel about it. So much that I sold my VSF and waiting for my Gold 226659 to arrive.
Reactions: Reaps
mattmcgarnsy
Alea iacta est
26/5/23
I'm in exactly the same boat here. Once you handle a gen the weight is magnificent and oddly beautifully balanced/weighted which makes you feel your rep is missing something essential. I see reps as works of art and much enjoy the feel in my hand equally as much as what can be seen. So much so that a tungsten rehaut, as terrible as they are, imo is a worthwhile sacrifice to get the weight right.
26,151
Not to rock your boat but the clasp is never tungsten on these watches, so you'll find it sits way worse than gen on Oysterflex. It's top heavy and will wiggle around if not seated properly.
26,151
Steel clasp sits 22g-24g. The head weighs 124g+. So 85-90f% of the weight is distributed on the head.
I'm not shitting on anyone, if you like it, it's your opinion. But it's very top heavy.
mattmcgarnsy
Alea iacta est
26/5/23
Ok so out of a 159g oysterflex original, how much of that is it's weight without the strap+clasp ?
And a 147g xing likewise, what is the ratio split?
Obviously going on memory here so don't remember a lob sided difference as much as an overall difference.
