VSF Upcoming Datejust 126334 with VS3235 72hrs Power Reserve
mari115
Put Some Respect On My Name
9/6/18
4,439
2,478
Nearer than you think
As beautiful as they are, will VSF rep the 36mm as well? Or will they stick with the pan-sized models?
YellowFin
Not pretty, hardly popular
28/1/20
2,527
2,800
Molvania
In my opinion the gen lugs are still definitively sharper than his ARF example but to each their own.
I actually compared my ARF DJ41 to my colleague's grey gen and there's no visible difference on the upper edge of the lugs. They both look more or less the same to the eye i.e. like on the picture below.
Duckber
1,585
866
Can you take a pic of your ARF DJ41?
Duckber
1,585
866
? That's my ARF.
You said "they look the same, like on this picture below" -- was not able to tell that was your rep. If that's the case then yes they definitely finally sharpened the lugs on the DJs. My v2 I have is very soft shaped.
YellowFin
28/1/20
2,527
2,800
Molvania
Mine is a V2 as well.
trustytime
Trusted Dealer
Trusted Dealer
3/4/16
1,653
1,274
before the movement you could think about dial.
new 126334 with movement 3235 has the crown painted at hour 6 under the stick (where in the old there is the “30”
Yes, VSF will be releasing the one without the coronet at the 6:00 position first, because the gen sample they bought was without it.
They will also release the updated version eventually.
peterpl
24/7/11
4,669
637
VSF Killing the Rolex game. They should have came into it earlier and made a killing. Noob factory is down the shitter - only their Daytona's are good because of the movement they have.
