SD43 Question for the modding experts
txpam
270
84
I have an XF SD43 and cannot find out if you can install a 3135 movement in it.
If so, does it drop right in?
If it requires mods, what are those mods....ie. movement ring, machining?
Want to install one in mine.
Thanks for the expert help.
txpam
270
84
Correction, I meant 3235
txpam
270
84
It has the A2824 currently.
32,783
59,020
The 3235 and 3135 dimensions (including stem heights) are the same. The 2824 stem height is very close. It's the 2836 stem height that is very different.
Its quite possible you can do this but it will not be a plug and play drop in. First test fit a 3235 movement with a dial on it and examine the stem hole position through the tube.
3135 in a 2824 case, this is what you want to see
The dial feet are in different places so the 2824 feet need to be clipped. You'll need to use a VR3235, not a VS as the VS has no dial feet holes given it is more gen-spec and takes a newer generation dial with underside rims and no feet. Then you'll have to glue or solder new feet onto the 2824 dial. Also you need new hands.
The 3235 stem will also have to be swapped over to the XF crown, and you may need a custom spacer.
People put 3135s in TC 2824 cases sometimes and there are other examples of this being done. Here is one I did recently.
Post #3
https://forum.replica-watch.info/for...7#post10722447
txpam
270
84
The 3235 and 3135 dimensions (including stem heigjts) are the same. The 2824 stem height is very close. It's the 2836 stem height that is very different.
Post #3
https://forum.replica-watch.info/fo...fit-3135-in-2824-case?p=10722447#post10722447
Thank you so much for the detailed response.
Very informative.
A gen dail will be installed if that makes any difference due to the dial feet.
32,783
59,020
Very informative.
Best case scenario would be if the gen dial has the underside rims, then you could use a VS3235. The VS3235 can be a little temperamental, if you are making a nice Franken you may want to consider a gen balance and bridge.
fall1n1
Registered Flex Offender
1,652
749
UK / Singapore
So the VS3235 does fit with no issues.
Woah that’s great to hear. The stock XF dial and hands fit fine, and stem placement didn’t need to be adjusted? Excited to swap out the movement on mine if that’s the case.
txpam
270
84
Well there are some gen parts in there. Dial, hands, crystal, bezel and insert.
32,783
59,020
Can you post a side profile pic? Interested in seeing how the gen crystal sits on the XF. The gen SD43 crystal is thick and sits a little high above the insert.
Gen SD43 from a video blog
txpam
270
84
I think it’s pretty close.
32,783
59,020
Yeah that looks fine bro. I put a gen SD43 crystal in a Noob not long ago that ended up about the same. Those crystals are really nice. Thanks for the pic, enjoy!
Noob with gen crystal
SS72
2,209
6,395
Australia
txpam nice work mate! One heck of a watch you have there now.
Will you be doing a gen DW?
