SUB CASE IDENTIFICATION HELP!
Ko67
1,224
119
I have a nice sub case that I took in trade in a modding job years ago. it has GEN construction and takes gen parts. It has screw cutouts for 3135 inside the case. The profile and CG's are decent, but perhaps a bit short. The engravings are correct in content, but a tiny bit small I think. Do any of the resident experts have any idea what case this is from the serial or the engravings? Thanks in advance. (And no, it is not for sale yet...)
d4v3
DO NOT TRADE WITH ME
20/3/13
910
264
Looks like BP to me, CGs short ( should look rounded from a side view) JF and ARF have bigger and pointy CGs
Source and more pics: https://forum.replica-watch.info/fo...rmit-16610lv-comparison-arf-vs-jf-vs-bp/page2
Reactions: Luvwatch
XpanzerX
1,043
489
If the serial starts with M or Z it’s likely a JF with the stubby crown guards
Ko67
1,224
119
Sorry for the double post…
Sent from my iPad using RWI
johloo
786
226
Unlikely to be JF since it has cutout for movement mount screw. Not BP because of gen crystal and bezel assembly unless someone machined it to spec. Not startime bc no holes and has engravings though engravings couldve been added. Can't be gen bc of shape of cutout... I think chances are that its a WM9 or TC with added engraving
Reactions: d4v3
Ko67
1,224
119
I am thinking it is very much like the wm9 cases I have seen before . All of these ideas are the reason j posted .
Sent from my iPhone using RWI
johloo
786
226
Does it fit the 3135 perfectly or is there some play after tightening mounting screw / stem hole height not lining up perfectly? My TC V6 with very similar cut out fits 3135 but isn't a perfect fit with those mentioned issues.
Reactions: XpanzerX
d4v3
20/3/13
910
264
JFs has not cutout for the screws Im thinking wm9/TC as johloo pointed
XpanzerX
1,043
489
Could be. If I remember early TCs had engravings. But I’m leaning towards WM9
Side note if you do sell let me know. I could always use a good 16610 case for project. Reserved sale of course.
Rx4Time
Supporter, Panerai lover
10,974
7,829
I don't think it's a WM9. Here's a picture of one I used to own. Notice no cut out at the 9 o'clock position.
Reactions: Ecender
DD60
Eagle Eyed Moderator
17,334
9,142
If the serial number begins M95XXX or V9XXXX
it could possibly be a Sean 16610T case. It's been a while, but the crown guards look like Sean.
Reactions: pompompurin
Ko67
1,224
119
It does seem a bit loose with the 3135 and you have to run the screws out a bit further to tighten the movement . The tc movement holder on the other hand, fits perfectly . Maybe it is a early, engraved tc ? Nothing seems to fit any other pattern of case .
Reactions: XpanzerX
johloo
786
226
That's the exact same issue I have with my TC V6 case using a 3135, the mounting screws would need to come all the way up until its almost completely out of the movement with half a thread left barely secure. The stem height also seems to fit a 3035 better where the 3135 hole would sit higher closer to the rehaut so it tends to pull the movement until mounting screws are tightened to push it forward to close the gap but creating tension on the stem.
Sounds like you're having the same issue so very likely its a TC or one of the variations of WM9 cases that TC used to use at some point.
bc1221
Put Some Respect On My Name
30/4/14
4,079
454
WM imo. I don’t think TC ever made a 16610-T engraved case.
