Presentation,
New project Super Franken Omega Planet Ocean Casino Royale "007" 45.5mm. with 1120 movement and Gen 2500 rotor.
In this project, up to the UPO Rep case, only Gen parts were used all parts listed at the SuperFrank Omega Planet Ocean Casino Royale "007". installed
, it took quite a while until I had ordered all gene parts but now it is time again.
Santre22 has built the 45mm franc Po Casino Royale "007" it was only gene parts used up the UPO case and I am really very satisfied with that Santre22 has again a wonderful
Franken Casino Royale built by him I also have the Gen movement holder and the Gen 2500 rotor which is a super graduation for the project
X21285 Omega 082SU1703 - Planet Ocean Black Bezel Insert
Omega 085ST0090 - Bezel Wire Clickspring
Omega 129ST0515 - Bezel Flat Click Spring
X22746 Glass Gasket (X22746)
X20079 Omega 062SB3063- Sapphire Glass
X20376 Omega OME-2500-Dial # 3 (064WK3170001) - Black Dial
Omega Planet Ocean Casino Royale "007" SPECIAL COMPLETE HANDSET 2907.50
42184ST Omega 069ST42184 - Crown
X12870 Omega 090ST1232 Case Tube
HE Valve. 086ST0115
HE tube. 090ST1242
HE Valve Head. 286ST0005
HE Valve Spring 085ST0067
Gen movement holder 2500
Gen 2500 rotor
Gen Omega Planet Ocean Stainless Steel End Link / 951 + pin & tube
Gen Omega Bracelet
Gen spring bars
Gen Caseback OME-112ST1703
Gen Omega Po End Link OME-026ST / 951 Stainless
Rep 45mm UPO Case
100m positive
santre22 super work as always thank you
for beautiful Franken Omega Po 007.
