I received my first rep from Toro last week and couldn't be happier. The Omea Skyfall 007 PO is, in my novice opinion, a very well produced rep. The weight alone gives the impression that this is a well built timepiece. At 42mm, it's comparable in weight to a 45mm gen Omega/Breitling. Just as important (to me), the movement is still within 1-2 seconds of the time I set it to when I received it over a week ago.
The only glaring mistake that I've found (and has been mentioned in other reviews) is the second hand tip is orange instead of red. The anti-reflective coating appears to be more clear than purple but under certain lights it will have a purple/green hue. The movement isn't fully decorated either but that is of little concern to me. So far, I'm very pleased with the Swiss 2824-2 and would rather have a higher quality movement than a properly decorated 21J Miyota. The lume is solid, not super bright but I certainly wouldn't consider it weak.
All in all, this is a great first rep and I can't sing Toro's praises enough for a smooth, informative transaction for this first time rep buyer.
