Hi all,
I wonder if I could pick the brains of some of you genius types.
I bought one of the new VSF Subs with their clone 3135 inside.
It felt awesome on arrival and seems to be getting good reviews, but mine's developed a wee issue.
When the crown is in the first/winding position, it sometimes doesn't wind. It seems that the little gear/wheel thing moves in the direction of the red arrow (on the photo below) when the crown is turned anticlockwise, but then presumably should move back and engage with the other wheel when the crown is turned clockwise. Sometimes it does (as it is doing in the attached video), but it often gets stuck in the disengaged position and so didn't wind, just free spins.
Is there an easy way to fix it? Is the problem due to friction where oil/grease will help? Or perhaps tightening (or loosening) of the screw keeping that piece in place? Or something more complicated in the keyless works? Something else??? Help!!!! As you can tell, I'm not very knowledgeable about this stuff.
Fyi, the watch works perfectly in the date setting and time setting positions (and in the video, it's working fine in the winding position too - typical).
Any advice would be much appreciated!
https://vimeo.com/482111903
This is video of it working properly (I think).
Comment
