My works
SMP_lover
Strap mastermind
Vendor (Strap Maker)
13/12/10
3,623
686
Heya fellas, the previous thread had more than half of the pictures unavailable due to expired accounts on hosting services so i'm starting a new thread with fresh pics.
SMP_lover
Strap mastermind
13/12/10
3,623
686
Lug covering wide safari hornback on daytona. Seems legit, right ?
Sent from my Pixel using Tapatalk
SMP_lover
Strap mastermind
13/12/10
3,623
686
One more
SMP_lover
Strap mastermind
13/12/10
3,623
686
Some roo goodness.
SMP_lover
Strap mastermind
13/12/10
3,623
686
The yellow one JEEEZZZZ Amazing. WIll that fit a XF Carbon Diver?? Again amazing work !!
It surely will. For diver though it has to be wider with oblong holes unless you want to wear it on the deployant.
stanevo6
computer says no
29/5/17
1,763
979
The Low Lands
Ah OK. I know the two Lugs (if you call them that) are fixed with the XF Forced Carbon Diver V1, the one I have.
do you have any price indication, If I may ask that is :)
SMP_lover
Strap mastermind
13/12/10
3,623
686
Fixed lug plots is not a problem, i've seen it all. I keep at least 10 midcases (Several diver cases, several 42mm ROO cases, several 44m ROO, LBJ, Legacy, several 15400 cases as well as a 15450 ). All those are needed to make sure my inserts fit well on those. So you can rest assured my strap will fit your watch.
Price for croc (non hornback) AP strap is $249 but i often give slight discounts for the returning or frequent customers as well as the first time customers to encourage them.
Pm me to discuss the strap specs and details.
stanevo6
computer says no
29/5/17
1,763
979
The Low Lands
SMP_lover Thank you so much for your answer. It is amazing to hear how much experience you have and to see those beautiful straps.
although your straps are worth the money for the full 100%, it is way out of my budget :(
of cause you are in my "favorites" in my browser. Thanks again !
SMP_lover
Strap mastermind
13/12/10
3,623
686
Hornback for the diver
Sent from my Pixel 2 XL using Tapatalk
Reactions: stanevo6
SMP_lover
Strap mastermind
13/12/10
3,623
686
BB
SMP_lover
Strap mastermind
13/12/10
3,623
686
Good old blue hornback
SMP_lover
Strap mastermind
13/12/10
3,623
686
Sel fit wide daytona gator
SMP_lover
Strap mastermind
13/12/10
3,623
686
Some rollie goodness
SMP_lover
Strap mastermind
13/12/10
3,623
686
Bet you don't often see a hornback strap on the 15400
Reactions: Tompa
SMP_lover
Strap mastermind
13/12/10
3,623
686
Nothing beats a nice hornback
SMP_lover
Strap mastermind
13/12/10
3,623
686
i would love to try one just to send to F off the bloody deployant...but is there any chance of a slimmer, sexyier buckle ?
Trying to be constructively demanding here, do not get me wrong
Well it's actually 19mm wide so not sure it makes any sense using an even slimmer buckle. I am in process of designing and then subsequently manufacturing forged carbon loops, so at least we'll check the sexy box if not possible with the slim one ;)
SuperLory
Well-Known Repist
22/10/15
8,515
5,124
Maybe i expressed myself badly, and i can’t sketch out anything now, but what i meant is if, say, that plastic squarish ring has a thickness, in its solid part, of ... 2mm ? I’d try a 1mm thick buckle so that it does not protrude laterally so much. Eventually (my) tomorrow i can show you what i mean..
