Case and strap link Gap
ANDFlow
67
49
Santiago - Chile
Hi, I’m getting a little bit annoyed about the Gap between the strap link and the case.
Can I fix this?
edit: NVM, tompa answered me.
but also is correct that the end link look off the bezel as we look in the pictures?
Also I want to buy a SS bracelet, should I have the same problem with the bracelet?
This is the AP ROO diver JF 9.5.
I put some pictures
Thanks
Enviado desde mi iPhone utilizando Tapatalk
Tompa
4,436
7,764
Sweden
You have flexible end links(plots) right? It is supose to look like that. But if you want change maybe an older generation of JF diver plots fits.
Skickat från min Sputnik satellit
Reactions: ANDFlow
QueTip
14,601
5,953
This is how it should be smh
Reactions: TESLA760
ANDFlow
67
49
Santiago - Chile
Yes, they are flexible, but they also look off the case in the pictures, that’s also correct?
Thanks you my friend!
Reactions: Tompa
legend
The RWI Dragon
64,069
81,633
Where I need to be.
It looks acceptable. At different angles of rotation of straps, the plots will look slightly different against the case.
Don't worry about this. If you have to worry, I can list the flaws of the watch, and what you mentioned isn't even on it.
You already know this is a replica, but what you are being bothered by is not a valid concern, there are tons of other flaws for this watch. Enjoy it as it is, it is a nice one for daily wear!
ANDFlow
67
49
Santiago - Chile
Thank you for your time to answer, and sorry, maybe I’m little obsessed with the watch. Dam.. I like it so much.
You mean the flaws of my watch, or the flaws of the JF v9.5 in general? anyway I would to know the list of flaws.
Tompa
4,436
7,764
Sweden
Bezel. Dw. Cyklop, etc.. :)
Tompa
4,436
7,764
Sweden
Bezel i mean the inner (rotating) bezel. Wrong/no outlines on numbers
Reactions: ANDFlow
Tompa
4,436
7,764
Sweden
But its a beautiful watch. Use it for what it is, a replica. Not a gen Audermars piguet. If you accept that there is no problem ;)
Reactions: ANDFlow
legend
The RWI Dragon
64,069
81,633
Where I need to be.
I’m referring to the flaws of the rep model in general.
- dive bezel numbers are missing the white border around the lume
- datewheel font is off
- cyclop is a tell
- dial is acceptable to me because the gens have variances among batches
- hands geometry is off
- check if your midcase is aligned with caseback. Misalignment of the two is a common issue that I’ve seen.
- of course (and this isn’t seen), movement is completely different from gen
- your plots/case gaps are actually one of the accurate features vs gen.
- straps and buckles are different but not an issue for me personally. They won’t be a tell on the wrist despite the differences.
Reactions: Allure and Repworld
ANDFlow
67
49
Santiago - Chile
- cyclop is a tell
Wow! Thank you again for taking time to answer! May I ask you if you think this watch is still a SuperRep?
Tompa Indeed I use it as a rep, so far and I have enjoy it very much! Now I want a 15400!
I loved all your comments.
Reactions: Tompa
legend
The RWI Dragon
64,069
81,633
Where I need to be.
No I do not regard this as a super rep but such an apellation is pretty subjective. As long as you like it and are comfortable with it, what I think is irrelevant sir.
Reactions: Allure
ANDFlow
67
49
Santiago - Chile
I’m enjoying it so far, but I’m a newb on this, maybe with time I will be more catchy.
What would you mod on this watch (Diver JF v9.5) or reasonable franken ( nothing more than 1k)?
legend
The RWI Dragon
64,069
81,633
Where I need to be.
Within $1k you say? Well then the cyclop, datewheel, and possibly a low beat movement conversion for a more accurate beat, and longer power reserve.
Reactions: Allure and ANDFlow
Repworld
6,374
1,594
- cyclop is a tell
I wish ZF fix everything please ZF Do it ..
Garuda
1,712
531
I checked with my TD and they said the new Delusional Factory 'DF' is working on a 1:1 diver with ghost outline tachy, gloss dial with 28 rings, correct font, supple strap and flexi plots. they bought the gen and have the best chinese minds make the moulds. release date very soon so you must get on pre-order queue
