Hi, does milk case accept eta movements with higher stem height of 2.25 mm (2836, 2846) or rather a lower one of 1.8 mm which is a spec for gen 1575 movement ((and also some eta such as 2824 or 2842)
Thanks
Milk 1680 case accepts ETA 2846 and 2836-2. It works perfectly for me.
As listed in my first post:
Ingredients:
- Milk 1680 mid-case
- Milk 1680 case-back
- Aftermarket insert with service fonts (not pictured)
- Vietnam pip from Ruby (not pictured)
- Vietnam bezel assembly from Ruby
- Vietnam T19 from Ruby
- Vietnam Rolex 1680 dial (no-lume)
- Replica Rolex 704 crown (RSC sometimes swap 704 crowns and 7030 tubes into vintage subs; therefore, this is still within gen spec)
- 7mm tube
- Rafflestime hands
- Rafflesdial movement ring (not pictured)
- NOS ETA 2846-2 lowbeat movement
- MMM (MyManMatt from Repgeek) open 6/9 DWO (the best open 6/9 dwo currently available, although not cheap)
Also, all gen-spec cases that are made for 1570 / 1575 movements can accept ETA 2846 or ETA 2836-2.
Some people can make it fit and some people cannot: what matters is the skill and the tacit experience needed to make it fit.
For your inspiration, here is a gen 1500 case (which originally uses 1570 movement) with an ETA 2846 inside.
- Gen everything (including the 7835 bracelet and hands)
- Modified ETA 2846 lowbeat movement (to fit gen hands and to remove the quick-set date function, like a gen 1570 movement)
- Cartel open 6/9 DWO
- Modified Helenarou movement ring
