ZF will release Fifty Fathoms 5008 40.3mm
steve_theonewatches
Trusted Dealer
Trusted Dealer
27/6/16
806
2,615
leebert
56
90
Great!
Please make sure that they get the rotor right for the 5008 - it’s not the Ocean Commitment version, but the standard version.
Merci!
leebert
56
90
Just following up - it appears (according to three TD's) that the rotor is the Ocean Commitment version for the 5008. Bummer. Was going to get this bad boy. Still might - have to assess how difficult it would be to replace the rotor with the proper one.
Reactions: Horace_Derwent
25,246
Are these really 40.3mm? I thought gen was 45mm? Might pick one up finally because it's sized to my wrist
It's typical ZF to be honest. That's why I love and hate them. Love because they release lots of watches that not many factories release. But hate because they're very sloppy with their watches in the details. They won't care and based on how ZF has done things in the past I am not going to hold my breath for a V2.
Reactions: leebert
Horace_Derwent
2,063
3,860
Cyberspace
Yes, ZF use the wrong rotor engraving for the 5008...sad
Reactions: leebert
Pinion Minion
2,637
10,418
Texas
Picked up an Ocean Commitment. A sloppy attempt by ZF.
Ignoring cosmetic differences with gen, The case is nicely brushed, but the bezel action is awful- it feels like a 30 dollar DHG watch. Upon pulling the stem to time setting position, the entire movement seemed loose. Opening the back I see they simply are relying on a not very well fitted movement ring- no clamps to hold the movement to the case. I had trouble finding screws that held a clamp for these- standard case clamps in an Asian case clamp kit would not go in so I had to use random screws from the parts box.
I'm not sure if the rotor material itself is the culprit, but helicopter noise is even worse than usual with this one despite lube. I may just put a standard Miyota rotor in and test. Lume is decent. I also will say the strap is surprisingly nice for a replica. I usually change my straps but I may keep this one.
Overall disappointed in this one- I had high hopes. Clearly ZF is not " committed" to making this a decent rep worthy of is price tag. ( Wordplay ..)
  • Sad
JayBee0815
Repoholics Anonymous
10,426
35,407
Heart of Europe
I rather suspect that you got a “Monday watch”. I had the Ocean Commitment and have the Milspec, neither of which have any problems with particularly loud rotor noises or with the movement clamps. However, I can confirm the rather mediocre bezel action.
Reactions: Pinion Minion
Pinion Minion
2,637
10,418
Texas
Looking at photos from a TD it appears they didn't put movement clamps from the movement to the case at all- just holder to case:
FugitiveBKK
28/1/25
New member here. I joined because this post caught my eye. Has anyone noticed that the movement clamps are absent from both ZF and GSF models ? It seems a bit sloppy. Is this causing problems for anyone ? Also, is there any way to improve the bezel action ?
Horace_Derwent
2,063
3,860
Cyberspace
Just received the new that (in Gen) Blancpain is relasing a new, limited edition of 100 pieces in 45 mm size.
It seems a very bland attempt to me...nothing special...
Reactions: Reaps
25,246
Butchered the case for no reason. Now it looks like a Seiko Tuna + Omega HE valve. Do they not understand why people like their watches?
Blancpain is horribly mismanaged......
