- 14/1/15
- 117
- 3
- 18
What's your method for polishing out machining lines from inside lugs?
I think I'd like to try this, but I'm an amateur at polishing cases generally, much less tight spots and corners like the inner lugs.
I searched and found multiple tutorials/discussions on case polishing generally, but nothing too specific on polishing the small area inside the lugs where machining lines are often visible (and in the inside corners where the lugs meet the case).
So, if you do this type of thing, what's your method for polishing the machining marks out and getting a high mirror polish on the inner lugs?
