Yachti 116622 Bezel & Crystal Gasket Dimensions
RedMouthguard
172
62
NYC
I am always using this site to gain value, so I figured it was only right I contribute.
If there is any watch smith beginners like myself who are over confident when doing crystal/bezel swaps and end up breaking their gaskets and need a replacement- but forgot to measure the dimension prior. I took some measurements before I ruined mine (thankfully).
Bezel Gasket:
Outer Dimension: 33.5mm
Inner Dimension: 32mm
sideview height: 0.7mm
Thickness: 0.8mm
Straightened out length: 104.8mm (cut and elongated)
Crystal Gasket:
Outer Dimension: 30.5mm
Inner Dimension: 28.9mm
sideview height: 2.4mm
Thickness: 0.6mm
