Wm9 16610 HELP!!
eswilly
3,022
198
Florida
I have a wm9 16610 going on 10 years now and she’s a non runner.
She needs a movement and hands. Any help or guidance is most appreciated!!!
Erik.
bobandshawn
3,443
327
Florida
That should be based on ETA, so you'll need a 2824 movement (Swiss, about $200)...not sure why you couldn't use the same hands?
Rx4Time
Supporter, Panerai lover
12,308
11,789
Verify what movement you have in there before you start looking for replacement movements or reaching out for repair services. I had one of these a few years ago and it had an odd movement. It was an ETA movement but it was a tiny one most likely for a female watch size. Here's some pictures of it below. I unfortunately don't have any clearer shots of the balance to see what caliper number the movement was. Might be able to locate the old sales thread or the text I typed in Google docs for the sale.
Reactions: Reaps
xray7
Amateur Rhetoric Wrangler
1,685
1,954
British Isles
I’ve got one of these in my endless array of “to work on” items.
Mine is the same story as the images above - mini ladies’ ETA movement which means the brass spacer can be drilled for dial feet for a gen dial if one is so inclined.
