I have two replicas now.
The Noob GMT Master II CHS: this one had the classic movement problem where the hour hand would begin to lag. It would keep nearly perfect time at I think +/- 4 seconds a day. However, after getting it repaired by the Noob factory, the time graph showed it at +8 seconds a day. Not too shabby I thought. This hasn't been the case now that I have it back. It gains well about 20-27 seconds or so in less than 24 hours.
The Noob Yacht-Master 116655 A2836 showed a time graph of +5 seconds a day. Again, not too bad. The watch actually has been gaining much more than that—probably around 15-20 seconds in a little under 24 hours.
Is this normal? Will it start to slow down some? As a novice, would it be easy to regulate to more accurate timekeeping?
