What movement is this? (Rotor problem)
coneman72
What movement is this? (Rotor problem) (Solved)
A colleague gave me a cheap TH replica to repair.
Without the rotor:
The problem: the rotor rotates freely a half turn and then locks
What should I check?
Thanks!
[YOUTUBE]ak0BB_ZouAM[/YOUTUBE]
ThinkBachs
DO NOT TRADE WITH ME
9/2/09
8,915
84
I'm no movement expert by any means, but if it were me, I'd put a drop of watch oil on the bearings to see if that make any difference.
SSTEEL
3,803
Looks like a 21J. What complications does this Tag have, if any? As to the rotor, ensure its fitted correctly to the circular/flat side fitting.
Check the underside of the rotor to see if its catching/rubbing anywhere which is restricting its full rotation.
coneman72
Only the rotor problem: rotates freely a half turn and then locks...
If I wind it manually, it works without problems.
Ko67
1,223
118
A broken or damaged tooth on one of the reverser / winding transfer wheels in the automatic winding system would behave just like that. The rotor can turn until the gears hit the damaged tooth and then locks up. I suspect that it will turn the other way until it locks again, right ? No way to know for sure without checking those wheels .
coneman72
Thanks for answer!
Today I will take apart the auto-winding system to check the gears.
coneman72
I finally found the problem: the movement had lost a piece of rubber that came out of the pushers. The loose piece inside the movement, stopping the rotor...
Pusher with rubber
Pusher without rubber
The problem
Case closed
