What is the best way to tight CG lever?
nardin
1,850
81
When it's getting loose... What is the best way to get it tight?
Any thoughts?
Thanks!
Sent from my SM-G930F using Tapatalk
capice
2,713
558
It should press against your crown not too tight, .......
nardin
1,850
81
And if its not?
kilowattore
14,159
6,866
Maybe you can adjust the hex nut on the crown tube. Failing that you can try the hot glue mod.
