Eh?hk45ca said:if you use the spring bars they take the place of the tubes so you don't have to worry about it.
Pugwash said:Eh?hk45ca said:if you use the spring bars they take the place of the tubes so you don't have to worry about it.
The spring bars replace the screws, not the tubes. Unless you're implying that the spring bars rotate, reducing wear on the leather, of course.
crick0234 said:i dont have tubes. Is that bad?
if anyone know something about pantie tubes as well, let me know
LevertonWatchAccessories said:crick0234 said:i dont have tubes. Is that bad?
I don't know anything about Pantie tubes, but all of your reps should have the tubes in the rep strap they came with check the ends of your rep strap's you might be suprised.
hk45ca said:you are correct. mine did.
